Canon announces the U100 remote control PTZ system for EOS R cameras.
Sep 20, 2020
3,179
2,468
Product main specifications:
host
Head weight: 4.25kg Load: ≤15kg
Battery life: ≥6h (uninterrupted use)
Operating voltage: 24V Working temperature: 0°~45° Continuous
power consumption: 24V
/ 1.5A peak power consumption: 24V/2.5A
Smart PTZ operation indicators:
Angle of action
Horizontal rotation angle
Pitch rotation angle
110°±10° left, 110°±10° right, 20° down, 45° up (0°
horizontally forward)
The structure is self-locking
not
Mechanical PTZ running indicators:
Angle of action
150° left, 150° right, total 300° down 30°, 60° up (0°
Speed of rotation
Manual adjustment, can be locked in any position to stop
Two camera lens indicators:
Target Search Camera
Smart Edition exclusive
Lens type:
Pixels,
Camera frame rate,
Focal length, 35mm
equivalent focal length,
Horizontal field of view,
Optical aperture, Video output,
Video recording format
Zoom lens
200W, with IR auto switching
50Hz
4.7~47mm, 10x continuously variable, autofocus
30~300mm lens
6.43°~60.9°
φ37.4mm
support 1080P
TS Stream File (Transport Stream)
Security surveillance cameras
Lens type:
Pixels,
Camera frame rate,
Focal length, 35mm
Fixed Lens 200W 50Hz
3.16mm
23.4mm Lens 132°
Ф12mm
Support
1080P HD
Large capacity battery
UB01
gimbal power supply
Battery type
Capacity
Nominal voltage Charging voltage Charging current
Charging time
25V lithium battery (polymer) 372WH (Wh)
25.9V 29.4V
Standard charging 0.2C fast charge 0.5C
Standard charging 6 hours fast charge 4.5 hours
It can be powered by the intelligent battery pack
UB02
gimbal
Battery type
Capacity
Charging time
22V lithium battery (polymer) 426Wh (Wh)
22.2V 25.2V
Standard charging 0.2C Fast charging 0.5C
Standard charging 6~8 hours
Fast charging 4~5 hours
The signal broker battery
UB03
signal broker is powered
Battery type
Capacity
Charging time
12V lithium battery(18650) 86.5WH (Wh)
11.1V 12.6V
Standard charging 8 hours
Fast charging 4 hours
dcm
Enjoy the gear you have!
1,091
856
Colorado, USA
The word Canon is conspicuously missing from every image. I do see another logo on every piece of equipment, but no idea whose it is.
It also doesn’t look like something that Canon (WW, Japan) would design IMHO. Here’s some PTZ cameras that Canon produces, most with a 1” sensor. It’s a long way from the U100 contraption.
3,179
2,468
I have tried to find an English release for this thing, so it's either Canon China jumping the gun or it's a regional thing.
It is not a Canon product.
It is a product called the Remote Camera Assistant from a Chinese company called Ueleret that has added a version for Canon cameras.
Canon Advanced Edition
details>
$3899.99
Delivery place:within the USA
Delivery time: within 15 days after payment
Canon already has the CR-S700R.
Canon EOS 40D
10,865
3,234
details>
$3899.99
Ahh ok, thank you
